The counter shaft is connected (even when the transmission is in neuttral)to the engine unless the clutch is depressed. So to turn the shaft, you have to tie the clutch down so it is disengaged. If you disengaged the clutch and could not turn the shaft, put the PTO in gear and then put something on the PTO to rotate the shaft. I use part of an old PTO universal joint with splines that fit on the PTO.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
