Don't think you can pull the bull pinion (brake shaft) without removing the bull pinion cage. I believe the inner ball bearing is pressed on the inner end of the bull pinion and won't clear the cage. The cage can only come out if the large bull gear is removed from the tractor axle.
Somebody will have to comment on whether one of the bull gears can be slid off the axle through the PTO opening and moved slideways to free up that axle. If so, you could then tow the tractor.
Frankly, I would rather make a dolly for the rear wheels or remove the wheels and tires and attach a truck axle to the drawbar. Or hire a wrecker to move the tractor.
As mentioned earlier, you probably have two sliding gears engaged in the transmission. That is a very easy fix on a 450. Remove the shifter column and align the notches on the shifter rails for the neutral position. That's a five minute job.
Today's Featured Article - On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play
... [Read Article]
Latest Ad:
[More Ads]
