Re: Farmall F-12 single front wheel question
Posted by J.J. from Afton on March 05, 2010 at 17:30:43 from (24.118.175.64):
In Reply to: Farmall F-12 single front wheel question posted by Dave13 on March 05, 2010 at 17:00:41:
There are two big cast iron bushings. I had the same issue with my F12. Instead of trying to search for good ones, I fixed the originals. If you are good with a welder and a lathe you can do that yourself or take them to a machine shop. On mine I also had to weld up the axle shaft and turn it true again in a lathe. Than I used the lathe to drill/reem out the center of the two busihngs so they were true again, than pressed a brass bushing into each, to fill the new gap, and so that they would wear rather than the cast pieces. After that I just sized the bushings for the new axle diameter, put it back together and its good as new.
Hope this helps you
-Jordan
This post was edited by J.J. from Afton at 17:38:32 03/05/10.
