I would remove the grounding wire for the time being. Rub those points with some 320 wet or dry until they're shiny. Then see if you have fire to your sparkplugs by pulling off a plug wire and hold it about 1/4" away from the sparkplug while a helper makes an attempt to start the engine. Make sure the tractor is out of gear. If you have a hot blue spark to the plug then see if the engine will start.
If you have a weak yellow spark you may have a weak coil or weak magnets that may not have strong magnetism. This is needed for your mag's coil to create a hot spark when they pass by the coil. Hal
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
