Re: Worth the risk?
Posted by Janicholson on March 06, 2010 at 08:29:33 from (64.61.211.57):
In Reply to: Worth the risk? posted by Pete D on March 06, 2010 at 08:06:25:
Very likely to run for ever that way. The price is good enough (if as described, and you run it for an hour or so to get it warm and feel it under your bum.
I would buy it and fix the TA, as the TA is a great tool for your intent, and could be as little as 200 to fix if it just needs a ramp and rollers to fix it. (depends on your repair skills) a complete TA will likely be less than a grand if you do the swap. JimN
