Well finding out id it is 6 or 12 is easier than testing the coil.
If the battery has 3 cell fill caps/holes, it is 6v. if 6 it is 12 v. With a volt meter it can be checked (across the two terminals) If it is running and charging use it until you decide to put it to original or leave it alone. the coil should draw about 3 amps. if drawing 6 amps it is the wrong one. If drawing 1.5 amps it could be a 12v on 6 volt battery.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
