Just wondering if any one knows how to test a coil to tell if its 6 or 12 volt.
ANSWER: Many original coils designed for use at 6 volts have a primary winding resistance as measured between their small + and - terminals around 1.25 to under 2 ohms (1.5 ohms typical)......THEY ARE LABELED 6 VOLTS
Many original coils designed for use at 12 volts have a primary winding resistance around 2.5 to 3.5 ohms (3 ohms typical)... THEY ARE LABELED 12 VOLTS
One reason being is so the points dont draw and have to switch too much over 4 amps so they dont burn up too quick. If you use a coil designed for 6 volts on a 12 volt tractor unballasted it can overheat badly, while if you use a coil designed for 12 volts on a 6 volt system the spark will be weak
NOTE Im NOT talking about high performance (Mallory and Accel etc) or elec ignition coils, Im talking many older original stock farm tractor coils for points and condensor ignitions THIS IS NOT A PERFECT TEST but when I was a used tractor dealer I used this method many many times AND IT WAS ALWAYS CORRECT. They could make a coil that would work at 6 or 12 volts but my best guess is its ohms would be well over 2. Still when you walk into NAPA they will ask if you want a 6 or 12 volt and will sell you one or the other more likely then they will sell you a UNIVERSAL coil for either 6 or 12 volts (I doubt they will have one)
NEXT does the tractor have a 6 or 12 volt battery?????????????
Is the genny a 6 or 12 volt??? Many 6 volt are black labeled while many 12 are red labeled
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
