I don't know if a similar reply was in the original thread. Your C has wet sleeves. You can pull the pan, and look at the cylinders from the underside. If you see water coming from between the sleeve and the block, green or otherwise, the cylinder sleeve rings are leaking. One of my C's is also leaking, have not had time to fix it yet. Otherwise, change the oil and anitfreeze. Run it a while, let it set long enough for the antifreeze to settle to the bottom, open the drain plug enough to make it drip -- you will see the antifreeze, particularly if green, if it is leaking from anywhere.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
