Re: How much paint do I need to paint a Farmall super C
Posted by CNKS on March 06, 2010 at 19:05:33 from (216.144.104.128):
In Reply to: How much paint do I need to paint a Farmall super C posted by Agricon on March 06, 2010 at 15:02:27:
A C was the first tractor I painted, it took about 5 quarts, I painted everything separately. A gallon of primer will do. I used epoxy primer over everything, and about a quart of sandable surfacer over the epoxy on the sheet metal Hardener was mentioned below. It contains isocyantes which can make you very sick, requiring a supplied air breathing system. I wouldn't use aluminum, because the rims were originally galvanized and dull. The CaseIH argent is probably ok. I use a GM rally wheel color. A quart or less is enough. Take some time and read all you can stand in the Paint and Bodywork forum, this site. A lot of opinions, you will learn a lot.
