Re: rear end oil in H's M's
Posted by CNKS on March 06, 2010 at 19:11:10 from (216.144.104.128):
In Reply to: Re: rear end oil in H's M's posted by sflem849 on March 06, 2010 at 18:56:08:
Hytran is the equivalent of about 10W. If you replace all the seals and gaskets first it is probably ok, otherwise leaks are likely. Shifting gears will be more difficult because the Hytran does not offer much resistance and 90W helps slow them down. (Ask my 460 that has to have a Hytran equivalent). It also costs more than gear oil, and has no advantage in non-TA tractors that I know of.
