Re: 504 PTO staying on at start up then stops after warm up
Posted by Owen Aaland on March 06, 2010 at 23:41:26 from (198.70.47.146):
In Reply to: 504 PTO staying on at start up then stops after warm up. posted by toro in texas on March 06, 2010 at 22:54:38:
The tool is a flat bar with a couple of curves in it. It is used to release the lock pin for the over center clutch adjustment.
The adjustment is for the clutch, not the brake. If the clutch does not slip and is fairly hard to engage, most likely the adjustment is OK. The brake is spring applied. If the brake lining is not worn out a common problem is the snap ring off the front end of the shaft.
