Posted by sflem849 on March 07, 2010 at 05:49:56 from (69.197.84.192):
In Reply to: Tool advice posted by sflem849 on March 06, 2010 at 17:56:43:
BSpauld said: (quoted from post at 05:37:37 03/07/10) I worked for several years at a Machine Shop and did a lot of farm repairs, We used Mapp gas and it worked great on everything I did,from cutting to brazing.It took different tips that a Acy does
I think he was referring to the ones plumbers use. I believe you are talking about MAPP instead of Acy on a real torch.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
