There is a butterfly controled by the governor, choke, venturi, four gas jets 90 degrees apart, and the safety shut-off diaphram that is overidden by an open throttle.
There is no float in the system. The regulator also serves as an evaporator. There is a high pressure valve and a low pressure valve with each one having a diaphram. Tractor coolant flows in and out. Fuel comes in through a separate filter as vapor or liquid depending on which tank valve is open. Fuel goes out as vapor. There is a vacuum line from the intake manifold. There is also one screw that requires adjustment.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
