Re: Removing Rounded bolts in tight spaces
Posted by tractorsam on March 07, 2010 at 13:30:11 from (142.68.49.211):
In Reply to: Removing Rounded bolts in tight spaces posted by Agricon on March 07, 2010 at 13:07:41:
Take a flat washer that fits over the head of the bolt, weld it on.
Then take a nut that'll also fit down over, weld it to the bolt and
washer. Wait for it to cool completely, remove the bolt.
If all else fails, use a cold chisel to knock the heads off the bolts
and then use conventional methods to remove the remains of the
bolts after the dash.
Sam
