Split the 340 U: Question re: the TA clutch
Posted by Moondoggie on March 07, 2010 at 14:16:15 from (66.187.36.126):
I split the 340U over the last 2 weekends to repair the TA clutch which was non functional. The TA assembly looks good. The pressure plate looks good as well as the back plate and the disk. But I can't get the 19/32" dimension between the the back of the back plate and the bottom of the pressure plate suggested in the IT manual. Seems either the fingers are worn or the surface of the back plate is worn by at least 3/16". At that dimension, the plate would be worn through. Should I just replace the plates and the disc and be done with it? Or am I missing something?
