tractorsam said: (quoted from post at 14:30:11 03/07/10) Take a flat washer that fits over the head of the bolt, weld it on.
Then take a nut that'll also fit down over, weld it to the bolt and
washer. Wait for it to cool completely, remove the bolt.
If all else fails, use a cold chisel to knock the heads off the bolts
and then use conventional methods to remove the remains of the
bolts after the dash.
Sam
I use a somewhat similar method. I use a larger nut with a hole about the size of the od of the nut. I also like to start taking it off as soon as the weld will hold. There is an added effect of heating the object that will help you get the bolt/nut out/off.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
