The steering valve is not centering, might be a loosened nut on end of spool, or damaged seal in side valve causing it to bind or could be in the actuating mechanism inside bolster that moves valve. Also, check that splined knuckle is not binding on shaft as shaft needs to be free to move in an out of bolster. You can take the cap off end of valve, held on by two allen head screws to check nut and observe valve movement.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
