Re: Oil contamination Farmall M?
Posted by Andrew Z on March 07, 2010 at 16:42:50 from (64.252.41.103):
In Reply to: Re: Oil contamination Farmall M? posted by 3500sport on March 07, 2010 at 16:33:26:
Yup just run it, the only thing that i would check
to make sure its coming up to operating temp. If the
thermostat has failed and stuck open then its hard
for them to get above 120 degrees. easy fix and
about 20bucks to fix. As for the filters, napa and
advanced auto carry them. You can get them off this
site as well.
Andrew
