Re: Cleaning an Oil Bath Filter
Posted by Al L. in Wisc. on March 07, 2010 at 16:45:40 from (216.226.92.151):
In Reply to: Cleaning an Oil Bath Filter posted by 3500sport on March 07, 2010 at 13:45:48:
Same situation on my 460U; I on a parts run, I had IH take apart the canister. The middle section was completely rust powder similar to coffee grounds and the top and bottom were junky. They used a power washer for cleanup. They ordered two packages of new material - still available. Now I need to find material to replace the gasket.
