Re: Changing HyTran oil - what Secret Tool Needed
Posted by bc on March 07, 2010 at 18:35:31 from (71.158.221.179):
In Reply to: Changing HyTran oil - what Secret Tool Needed posted by John Athey on March 07, 2010 at 17:15:08:
I can tell you I was using some key stock to remove the top bull plug for the tranny fill hole and busted out one side of it. King Kong here wanted it tight so maybe snow over the winter and rain will not leak into the tranny. WD 40 works wonders but it was too late when I used it. If that is a regular pipe thread then I'll get another with a square nubben on it for a regular wrench.
When you use the side plug to fill it up to level, get a stick, tape, dowel, or whatever and make you own dip stick to check the oil. Then you will never have to pull that side plug again.
