Re: farmall md engine gaskets
Posted by Andrew Z on March 07, 2010 at 19:42:33 from (64.252.41.103):
In Reply to: Re: farmall md engine gaskets posted by jim warehime on March 07, 2010 at 19:31:57:
the pan is very easy just take off and clean and replace. If you need to replace the pump mounting gasket then youll need to remove the front timing cover for the injector too. Personally for the cover i would use RTV. You will also have to remove all the lines going to the pump, fuel inlet,return, and injector lines. You cant really get the timing messed up because when you remove the pump there are marks on the gear and on the hub of the pump just make sure to line them back up when replacing. If i was you i would invest in a manual if you dont have one already, there a world of help when dealing with these diesels.
Andrew
