The primary friction element is between the two surfaces. When new ours had (remember this is remembering) a square shanked round headed carrage bolt up from the bottom through the center, this bolt was ~ 1.5" long and had a small diameter heavy wt spring over it. on the spring top was a cup shaped washer with edges turned down. to keep the spring straight. A smaller washer and and castile nut (cotter pin grooves on top) was used to tighten the spring. Two holse in the bolt kept the cotter and provided adjustment. It had a fiber disk in it when new, (like conveyer belting) but we eventually replaced it when it went "away" with leather. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
