Re: MW hand clutch and belly pump question
Posted by Zachary Hoyt on March 08, 2010 at 09:44:59 from (74.33.209.212):
In Reply to: MW hand clutch and belly pump question posted by ryanwheelock on March 08, 2010 at 08:05:42:
The belly pump runs off the front end of the countershaft and the PTO runs off the rear of the countershaft. It's driven by the constant mesh gear on the input shaft. My understanding is that the hand clutch 'breaks' one axle so that the differential applies all the power to the disengaged hand clutch, since a differential will always power whichever side is easier to turn. It's the same effect as if you magically put a patch of ice under one rear wheel and it spun.
Zach
