Re: IH Torque Amplifier trouble
Posted by pete 23 on March 09, 2010 at 08:46:21 from (173.87.0.197):
In Reply to: IH Torque Amplifier trouble posted by Robert Nighswander on March 08, 2010 at 15:42:13:
Stuck in low, does this mean lever doesn't move, or mean lever moves and valve doesn't move, or lever and valve both move but still drives in low. These are some things you will need to determine. It may have blown the direct drive clutch causing low only and also the noise. I would say you should be able to determine if noise is limited to ta by shifting speed trans into a neutral position. There is actually no detented neutral but you can find it between gears so as only ta and counter shaft are turning when clutch is engaged and there fore the problem would be limited to that section of power train.
