Posted by bc on March 09, 2010 at 08:50:12 from (71.158.221.179):
In Reply to: 606 loader problems posted by mburrow on March 08, 2010 at 20:22:44:
I'd check to see if the relief valve may be stuck open with something under the ball. On the block attached to the rockshaft housing, there are one or two. The big one takes about an 1 1/8 wrench if memory serves me right or maybe it is 7/8. Follow the return lines back. IH seems to have plenty of pop off valves engineered into everything. Look for one on the valve as well. Anywhere you see a bolt head where there probably isn't a bolt is probably a relief valve than can get gunked up and open. Grab and wrench/socket and check them. Some use a check ball that could fall out so check the I & T 25 manual.
There is also a relief valve under the cover under the seat on top of the rock shaft housing. I found a piece of broken spring in mine holding the ball open. Put it in the vise to compress the ball and it fell back into the valve. Come to think of it, that may be part of my problem still. Guess I'll have to buy a pressure guage and fittings.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
