Re: Plate behind carb / manifold Farmall M
Posted by MisterT on March 09, 2010 at 11:37:20 from (209.152.78.140):
In Reply to: Plate behind carb / manifold Farmall M posted by farmallsuperc on March 09, 2010 at 11:29:51:
3500sport said: (quoted from post at 20:29:51 03/09/10) Does anyone know the purpose of the plate on the left hand side of the block directly behind the carburetor and manifold? I just noticed that mine is missing a couple bolts/studs and the holes were filled with RTV! Pictures coming soon...
That plate is the "water header cover", also called the water jacket cover. The RTV is probably sealing up the holes where the bolts have been twisted off.
