Re: 606 loader problems
Posted by Brad Motheral on March 09, 2010 at 12:13:47 from (96.63.36.141):
In Reply to: 606 loader problems posted by mburrow on March 08, 2010 at 20:22:44:
just had the same thing happen to me. it was the flow divider valve. inside the input port from the pump there is a small soft plug with about a 1/8 inch hole in it. this allows about 3 gpm to go to the power steering and diverts the rest to the aux remotes. the plug in mine was turned sideways allowing all the oil to go to the power steering and none to the remotes. i simply took it out and reinstalled it properly in its seat and all was good. sometimes the plug is missing altogether and you have to make one. this plug is NOT in the schematic and i don't think is listed with a part number. you may have to look inside another flow divider to see it. good luck!
