Re: 350U running lean
Posted by CNKS on March 09, 2010 at 18:29:32 from (216.144.104.128):
In Reply to: 350U running lean posted by Formerly PaMIke on March 09, 2010 at 17:37:07:
Electrode should be gray or even almost white with the correct mixture, but brown is better than black. With 5 turns out you are not likely to get a clean plug unless you run full load for a few hours. As stated in the other post, clean the carb and put a kit in it. Spray on carb cleaners won't do much. Then experiment and set the main jet at about 3.5 turns out. If it pulls what you want it to, it is ok.
