Re: Compatible Fluid with IH HY-TRAN
Posted by IaGary on March 10, 2010 at 03:18:24 from (207.177.17.153):
In Reply to: Compatible Fluid with IH HY-TRAN posted by Mich John on March 10, 2010 at 02:06:50:
You can use most any hydraulic oil in IH and get along just fine. You can even use the JD HY Guard in the IH tractors and get along just fine.
But JD has to have JD fluid or the hydraulic brakes will get to chattering on some JD models.
The JD fluid has an additive to keep the brakes from chattering.
This is what I was told some 30 years ago.
