Posted by farmallhal on March 10, 2010 at 10:48:10 from (71.1.111.67):
In Reply to: Touch Control fluid posted by Mark W. on March 10, 2010 at 09:25:55:
You need to obtain a copy of the Blue Ribbon Serviceman's handbook GSS-1024 as the filling process is quite involved. This can be obtained from binderbooks dot com unless your CaseIH dealer will run you the necessary pages. The touch control manual due to when it was published lists the approved fluid as Touch Control fluid which is no longer with the current correct fluid being Hy-Tran or one which meets the same specs. Doesn't list the total amount required as it would depend on various hydraulic features on your tractor, ie., remote valve, fast hitch, loader, etc. but full after going through the specified process is 1/2" below the fill plug on the left hand side of the TC unit. The serviceman's handbook noted is for Farmall Touch Control systems on the Cub, Super A, AV, Farmall C and Super C and the International Super A tractors. I'll let someone else advise on how to flush the system but I would think there are few acceptable fluids suitable for flushing other then just clean Hy-Tran and changed after a short run time. Hope this helps, Hal.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
