hey PA, just for the heck of it you should make sure that there are no additional vacuum leaks around the intake, if you found one there might be more causing a lean A/F mix, and that would make adusting your carb seem impossible. grab you a can of carb cleaner at the auto parts store and gently spray it around the carb base and the intake and see if your idle picks up, you can pin point a very small vac leak this way. also you can spray a little carb cleaner right into the intake/carb throat and see if it runs better by artificially inriching like this will also tell you your not getting the right amount of fuel and you have some sort of fuel restriction...and or vacuum leak..
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
