Posted by ScottyHOMEY on March 10, 2010 at 19:48:56 from (70.105.237.152):
In Reply to: Re: Kill Switch posted by sflem849 on March 10, 2010 at 19:22:23:
I agree. The "normally closed" description is a little confusing. I grew up tih the old ST/DT, SP/SP nomenclature, which (I hope) still has some validity as such conversations go. To my ear, "normally open/closed" indicates a swith that requires a momentary action to make or break the circuit. It doesn't apply to switches with two defined positions.
Bottom line, if what Two Banger has in hand is an original style Farmall switch, he will need the two pole type designed for battery ignitions, which will have two poles on the bottom, both of which are insualted from ground. The single-pole type of the original Farmall switch, intended for magneto ignitions, grounds through its body, and does not provide any continuity (in either position) between a source of battery power and the igntion.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
