Re: Kill Switch
Posted by Bob on March 10, 2010 at 20:59:41 from (69.178.228.68):
In Reply to: Kill Switch posted by Two Banger on March 10, 2010 at 18:32:28:
Connect the switch to chassis ground and the points side (EI side) of the ignition coil.
Switch closes, it's just like the points never open (or the EI's shorted out )and the engine will die.
Of course, those of us that grew up around hay balers or swathers with Wisconsin engines will have an easier timer understanding this than the rest of you!
(Those suckers had a cylinder head temp switch that would close and "kill" them if they overheated.)
