Re: Cub carb
Posted by Jim Broughton on March 10, 2010 at 22:34:53 from (4.243.30.14):
In Reply to: Cub carb posted by JDnTN on March 10, 2010 at 20:23:42:
Jim Becker is exactly right !! Unscrew that brass nut on the side of your carb and take out the long brass stem, and as he said clean it carefully, especially the one on the end of the tube...use an acetylene torch wire cleaner or a SMALL needle, being careful to not break off the wire/needle and to not enlarge the hole ..put it back in and she will run just fine !
Jim B. in Oregon
