Posted by Owen Aaland on March 11, 2010 at 01:37:35 from (65.161.86.87):
In Reply to: hydraulic leak posted by ntmoore on March 10, 2010 at 16:57:49:
Looks like a standard JIC hydraulic fitting. The top and bottom ends are 37 1/2 degree male ends, the one on the left is female NPT. If the fitting has not recently been disassembled, look for a crack in the pipe where the flare first starts. Most easily seen from the inside. Caused by vibration on a pipe not supported near the fitting.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
