This is one of those things where YES it will pull it BUTTTTTTTTTTT it wont, in my opinion, pull it as it should be pulled such as an M would.
If you put an H on a good heavy 10 ft wheel disk with good big blades the first time over plowed ground IT WILL WORK IT TO DEATH AND SLIP THE WHEELS and woller all around versus what again a heavier M would do. You dont have the weight or HP or traction thats needed.
Same on a heavy chopper, you need to keep the RPM up and if you want to run at any reasonable ground speed Id say a 12 footer would be hard on a little H
Again, it will work BUT NOT THE WAY ID WANT TO DO IT LIKE AN M WOULD
Its your tractor and your choice but you asked for opinions and mine is thats more of a load then Id like on an H
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
