Posted by The tractor vet on March 11, 2010 at 15:19:33 from (75.19.124.251):
In Reply to: D-361 timing marks posted by pete 23 on March 11, 2010 at 10:43:40:
Ya know Pete i have never paid that much attention to that over the years as when i do a 361 i always pull them and do a total rebuild and use the .010 sleves to make sure that the core shift is out of the block as i have them line bored and then set up off the centerline for the boring and a light dusting of the deck and a light cut on the contour bores and have always set TDC off the timing marks and i guess i have always assumed that they were correct and it is set at what i have always believe to be TDC . then put the ft. cover on then the pump after i have it setting in the chassie . I know way back when Ford was still using the FE block 360 in the pickups that the ft. harmonic Balancers on the 70-71's were way off and trying to get one to run at 5 degrees BTDC was a real treat as it was off by 15 and if you set them at 20 they ran great . So now i will have to check real close on the next one and see .Thanks for the heads up .
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
