Re: Farmall M carburetor
Posted by Andrew Z on March 11, 2010 at 18:49:40 from (64.252.41.103):
In Reply to: Farmall M carburetor posted by m.r.vmax on March 11, 2010 at 18:41:22:
sounds like you have debris in your tank, i would pull it off and clean it your self or send it out. Check the bowl as well you could be plugged right there. If you are then i would suggest you get the tank cleaned as well. But really sounds like a fuel starving issue
Andrew
