Re: 504 PTO staying on at start up then stops after warm up
Posted by charles todd on March 11, 2010 at 19:51:51 from (205.242.95.131):
In Reply to: 504 PTO staying on at start up then stops after warm up. posted by toro in texas on March 06, 2010 at 22:54:38:
You may be able to adjust the linkage to the IPTO (I assume it's IPTO) and put more tension on the brake. I adjusted mine about 2-3 turns of the clevis and it stopped the IPTO from spinning while not attached to a load. Good luck.
CT
