Re: Need info on a 101 fertilizer unit and a 180 planter
Posted by SaTom on March 11, 2010 at 20:57:15 from (76.23.205.193):
In Reply to: Need info on a 101 fertilizer unit and a 180 planter posted by OB OBrien on March 10, 2010 at 08:45:47:
I have a 180 planter manual that also covers the older fertilizer unit with the galvanized hopper. There are tables in here that provide all of the information you need. As far as seed spacing, I need to know what planter plate you have, and I can tell you what sprocket to put on the countershaft and on the feed shaft to achieve the desired spacing. As far as fertilizer goes, it depends on what notch number the lever on the side of the hopper is on and how many pounds per acre you want to put down and I can tell you which sprocket to use. Also, I need to know which feed wheel you are using. Let me know what you have and I can match it up in the book...
