Posted by The tractor vet on March 12, 2010 at 08:43:10 from (75.19.124.251):
In Reply to: m engine posted by johnyo36 on March 12, 2010 at 08:11:54:
You could be getting antifreeze from the head or just a bad head gskt. or it could vary well be the block is cracked behind a sleeve ??? don't know for sure and the only real way to find out is , yep yo guessed it to take her all the way down and look as you go . If you know how to read a head gskt for signs of leakage yo may find that it was just the head gskt. But for me i am never that lucky . As for the head yep they do crack and this may be the problem. Here again you may be able to see a crack after ya get here cleaned up and look then you may have to have it tested by someone that knows how to do it and many times today they do a half arres job of it . as i have seen one tomany times where they will say yep it is good no leaks COLD but put a little heat to it she will look like old faithful as a dry air pressure test sometimes will not show but do a hyd. test with 40 psi air and warm it up whole different ball game . If it is indeed cracked behind the sleeve don't panic a good machine shop can bore that hole out and press in a repair sleeve and rebore it to take a new sleeve and it is FIXED . It was just the block stress relieving it's self. The MD's -450D's were good for this .
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
