The only gear reduction starters I've seen for an M use the original pieces but the armature is cut off and a pinion gear is installed on the end. An additional housing is added between the case and drive end frame that contains a ring gear on a shaft which also uses the original starter drive. It makes the started about two inches longer and the case is offset from the drive end frame.
The MD uses a heavier starter than the gasoline model.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
