Re: Super A Fan Bearing
Posted by haas on March 13, 2010 at 15:43:47 from (75.223.111.178):
In Reply to: Super A Fan Bearing posted by Derrick In NY on March 13, 2010 at 10:52:14:
Centrifugal force keeps the oil from leaking, not the seal. You may have too much oil in the chamber. To fill it, turn the fill opening to the side and fill with oil. Then turn the fill opening down and let the excess drain. There is a stand pipe(provided it is still in there as designed) in the chamber to let oil be at correct level when drained with the fill opening at the bottom. Then put the screw back in the fill hole. There is supposed to be a gasket on the fill screw. If that is missing, could cause leak. When running, centrifugal force keeps the oil away from the shaft seal.
