Posted by jimb2 on March 13, 2010 at 19:05:14 from (99.240.236.11):
In Reply to: Re: IH 464 (Diesel) posted by carlsandberg on March 13, 2010 at 16:04:13:
Hi Carl, from the rear of the tractor, you have to be concerned with the fuel line that comes out of the bottom right of the fuel tank. The left hand side has the return fuel line and the cross over fuel line to the right side. The return line has a check valve on it so fuel will not run back out of the tank. Usually you have to remove the lines and the shut off valve out of the bottom right fuel tank. The left shut off valve only keeps the fuel equal in both sides of the tank. There is also the fuel tank vent tube on the left side as well.
So check fuel flow from line at bottom right of tank this is the input to primary fuel filter.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
