The original Farmall M was 6 volt whereas the Farmall MD used a 12 volt system (two 6 volt batteries in series to give 12 volts). Compared with the 6 volts for the gasoline/kerosene/distillate engines with from 4.25 to 1 (kerosene) up to 5.9 to 1 (gasoline) compression ratio engines the 12 volts would handle the MD with 6 to 1 compression ratio on gasoline for starting. The Farmall MD was only about 14 to 1 compression ratio on diesel, about as low as one can go for diesel engine. My small IH German built D-214 2 cylinder diesel engine has a 19 to 1 compression ratio.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
