Chimimg in here, I would check the integrity of the Gen output wire from the gen Arm terminal to the VR, From the VR bat terminal to the Amp meter, and from Amp meter to the Starter switch Bat terminal. This should be #10 stranded wire. If it sees more than a .5 volt drop across any link, or any through a terminal, I would replace it with new. A fully charged battery is also needed to determine fundamental charging voltage and current. Otherwise the battery draw will determine both, and confuse issues. With the VR in place, do not connect the 4 position switch to the VR at all. (just a reminder) Jim
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo
... [Read Article]
Latest Ad:
[More Ads]
