Posted by pete 23 on March 14, 2010 at 17:12:54 from (173.87.0.197):
In Reply to: Hydro 86 Update posted by Matt Compton on March 14, 2010 at 14:52:41:
Well, the first thing I would do is cap the lines coming from hydro to control valve with "steel" caps. This will tell you if weak hydostatic drive is internal or external. Could be as simple as a leaking foot n-inch valve. Also, verify that the two lines have not been reversed as this will give you low drive pressures also. Caution when you do this as you will have no contol of motion with the foot n inch pedal, only the SR (speed ratio) lever. Do it out in the open spaces.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
