Posted by D Slater on March 14, 2010 at 18:21:41 from (72.65.138.104):
In Reply to: Farmall 340 TA posted by Tom Hunter on March 14, 2010 at 08:43:59:
If its staying in the low side T/A with handle moved both ways, there's a problem with the T/A clutch. Its not engaging or holding. Unless the linkage is realy messed up and not letting the t/a release bearing back off from the t/a clutch fingers, slim chance in my opinion, you are needing a split behind the engine and top cover removed from T/A housing to remove other parts and the clutch. If oil is leaking into the T/A clutch compartment another split at rear of T/A housing could be needed.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
