Re: Farmall 450 (Gas) Wiring
Posted by John T on March 15, 2010 at 06:41:12 from (71.55.30.174):
In Reply to: Re: Farmall 450 (Gas) Wiring posted by old on March 14, 2010 at 21:00:30:
Rich, where he as the diode wired IS NOT THE PROBLEM. Even though its not where we often wire them (on key switch output or coils input) where he has it has the same affect, to excite the alternator ONLY once we turn the key on as its then a hot battery voltage source. The nearly same hot battery voltage source is equal at the Keys Output,,,,,,,,,,The push switches Input,,,,,The ballast Input. i.e.where he has it should work fine I HOPE HE DIDNT HAVE WRONG POLARITY AND FRY HIS ALTERNATOR???????
See my post above, hope this helps, hope all is well with you in Missouri
John T
