Re: Farmall 450 (Gas) Wiring
Posted by John T on March 15, 2010 at 08:40:35 from (71.55.30.174):
In Reply to: Re: Farmall 450 (Gas) Wiring posted by Tony_Idaho on March 15, 2010 at 08:25:21:
Just so I am understanding correctly..
Both the #1 and #2 need to be at the 12v when the Key is switched on? Is that a correct statment?
YES, No 1 is at 12 from the key, (when ON) No 2 is at 12 (always) as its connected to the ammeter
And the Diode is in the correct position, sounds like Yes, but could be somewhere else also...?
Its fine where it is, I normally wire them direct to the output side of the key switch, but your at the same point electrically.
Should I get a bigger AMP rating (like the 6Amp mentioned?) How many AMP should be going to the #1 position?
A 3 amp should suffice, theres less then an amp to excite the alternator UNLESS theres a problem ??????????
John T
